Blackview AirBuds 5 Pro IPX7 Wasserdichte True Wireless Stereo-Ohrhörer
€78,95 €57,95
✔Hybride aktive Geräuschunterdrückung
✔Dreifachmikrofone zur Reduzierung von Anrufgeräuschen
✔Super druckvoller Bass
✔IR-Näherungssensor
✔IPX7 wasserdicht
Beschreibung
AirBuds 5 Pro
Hear the magic without interruptions
Hybrid Active Noise Cancellation 丨 Triple Microphones 丨 Punchy Bass
AirBuds 5 Pro
  • IR Proximity Sensor
    Smart wear detection
    Smart wear
    detection
    AirBuds 5 Pro
    AirBuds 5 Pro
  • 5-minute charge
    3-hour audio enjoyment
    AirBuds 5 Pro
    AirBuds 5 Pro
  • Hybrid ANC &
    audio quality compensation
    AirBuds 5 Pro
    AirBuds 5 Pro
  • Single ear use
    AirBuds 5 Pro
    AirBuds 5 Pro
  • AirBuds 5 Pro
    Support wireless
    charging
    AirBuds 5 Pro
  • AirBuds 5 Pro
    Five sizes of soft tips
    AirBuds 5 Pro
  • AirBuds 5 Pro
    5.0
    AirBuds 5 Pro
  • AirBuds 5 Pro
    IPX7
    waterproof
    AirBuds 5 Pro
  • AirBuds 5 Pro
    Triple microphone noise cancellation for calls
    AirBuds 5 Pro
  • AirBuds 5 Pro
    Punchy bass
    AirBuds 5 Pro
Five Sizes of Soft Tips
Find the Best Fit for the Best Sound
 The size of earbud tips matters when it comes to noise cancellation. AirBuds 5 Pro come with five sizes of soft tips for a custom fit. The result is an exceptional seal for noise cancellation.
12.60mm
Medium
  • 14.20mm
    Maximum
  • 13.40mm
    Large
  • 11.80mm
    Small
  • 11.00mm
    Minimum
AirBuds 5 Pro
A Wonderful World without Noise
AirBuds 5 Pro are equipped with the dual-core digital noise reduction chip and the enhanced hybrid active noise cancellation (ANC) technology, which combines feedforward and feedback ANC. With a noise reduction depth of 35 dB, AirBuds 5 Pro eliminate ambient noise and create the most attractive musical landscapes for your mind to wander around in.
  • Noise Frequency
    AirBuds 5
    30Hz-2kHz
  • Noise Reduction depth
    AirBuds 5
    -35 dB
AirBuds 5 Pro
35 dB In-Depth Noise Reduction, Redefine Music Clarity For In-Ear Peace
AirBuds 5 Pro
  • A Good Partner for Commuters
    Metro, bus, street, etc. Free from noise with hybrid active noise cancellation.
    AirBuds 5 Pro
  • Enjoy Quiet Travel Time
    Thanks to hybrid active noise cancellation, AirBuds 5 Pro give you a quiet world.
    AirBuds 5 Pro
  • Quiet Sleep-Easy Solution
    Listen pure soothing sound with hybrid active noise cancellation. Sleep better and wake up refreshed.
    AirBuds 5 Pro
  • Calls like Face-to-Face Conversations
    AirBuds 5 Pro
  • Triple Microphone Noise Reduction
    Thanks to the triple microphone noise reduction technology and air ducts designed specifically for preventing noises of wind, AirBuds 5 Pro capture your voice clearly even in a crowded environment. The result is that calls sound like face-to-face conversations.
    Noise
    AirBuds 5 Pro 0 dB
    Voice
    100%
Audio Quality Compensation Just like in a Live Concert
In order to avoid loss of audio quality from noise reduction techniques, AirBuds 5 Pro are equipped with the audio quality compensation algorithm, allowing every note to be restored to its original brilliance.
AirBuds 5 Pro
Graphene-Based Speaker Super Punchy Bass and Fine Details, Always in Opera
The 7mm dynamic coil driver comes with the sensitive graphene-PU composite diaphragm, which is ultra-thin, but strong and flexible enough, helping in delivering punchy bass and fine details. The result is an ultimate listening experience.
Graphene-PU
composite diaphragm
7mm
dynamic coil driver
AirBuds 5 Pro
IR Proximity Sensor
Smart Play and Pause, Never Miss a Beat
Thanks to the IR proximity sensor and the gravity sensor, AirBuds 5 Pro deliver an unparalleled magical listening experience. They automatically stop when you take them out of your ears, seamlessly resume when you put them back.1
Automatically pause when
removing the earphones
Play automatically
when wearing
AirBuds 5 Pro
Single Ear Use
Each Earbud Has Its Own Brilliance
 Connect each earbud to separate devices, and enjoy two different worlds simultaneously.2
AirBuds 5 Pro
5-minute Charge
3-hour Audio Enjoyment
AirBuds 5 Pro have remarkable endurance, delivering 24 hours of battery life together with the charging case, and offering nearly 3 hours of audio enjoyment from only a 5-minute charging for the charging case.
  • 24hrs
    of listening time with multiple additional charges in the case.3
  • 4hrs
    of listening time on one charge for the earphones.4
  • 3hrs
    of listening time from only 5 minutes of charging for the charging case.5
AirBuds 5 Pro
Indicator light description
* Open the charging case when earphones are in it, put earphones in or take them out to activate the LED battery indicator.
LED Battery level of earphones
stays red on for 2s 0-15%
stays orange for 2s 15%-90%
Stays green for 2s 90%-100%
*Open the charging case when no earphones are in it to activate the LED battery indicator.
LED Battery level of the charging case
stays red for 7s 0-20%
stays orange for 7s 20%-80%
stays green for 7s 80%-100%
Time & LED Purpose
long press the button for 3s,
the light flashes white
pair your smartphone with AirBuds 5 Pro
long press the button for 10s,
delete previous pairing memory
* When both earphones are in the charging case, the LED battery indicator indicates the one with lower battery level.
AirBuds 5 Pro
How to Pair Your Smartphone with AirBuds 5 Pro?
  • Step 1
    Turn on switch on Your Smartphone.
  • Step 2
    Long press the button for 3s until the light flashes white.
  • Step 3
    Search for AirBuds 5 Pro on Your Smartphone.
  • Step 4
    Click "AirBuds 5 Pro" and then pair your smartphone with AirBuds 5 Pro.
AirBuds 5 Pro
Support Wireless Charging
More Solutions, More Freedom
 AirBuds 5 Pro's charging case comes with a USB Type-C port and you can also charge it simply by putting it on a charging mat. It takes 2 hours to be fully charged with a 1.5W wireless charger.
Orange:Charging
Green:Fully charged
*AirBuds 5 Pro do not come with a charging mat.
AirBuds 5 Pro
 Ergonomic Design & Scratch-Proof Coating
Always Keep Fit & Every Detail Perfect
 Innovative structural design exists purely to serve your all-day comfort. AirBuds 5 Pro have undergone hundreds of rounds of optimization and upgrading to achieve a superb structural design. Additionally, the special coating protects your earphones and charging case from scratches while maintaining a stylish appearance.
AirBuds 5 Pro
Smart Tap Control
It Couldn't Be Easier
Play music, skip songs, pick up/end calls, and turn on/off ANC simply by tapping on AirBuds 5 Pro.
  • Tap right twice
    Play music
  • Tap right twice
    Next song
  • Tap right twice
    Answer / end a call
  • Tap right three times
    active voice assistant
  • Tap left twice
    ANC switch
AirBuds 5 Pro
  • 5.0
    Transmission Faster and More stable
    Enjoy fast and stable audio transmission powered by 5.0 technology. Thanks to its stable connection and a transmission distance up to 10 meters, you can keep playing music smoothly.
    AirBuds 5 Pro
  • IPX7 Waterproof
    No Fear of Rain or Sweat Challenges
    AirBuds 5 Pro are professionally designed for IPX7 water resistance. Whether you are in the gym or have an outdoor activity, they are always reliable enough.
    AirBuds 5 Pro
AirBuds 5 Pro
Model AirBuds 5 Pro
Product color White
Driver 7mm dynamic driver
Driver sensitivity 100dB @1KHz
Frequency response range 20Hz ~ 20kHz
Microphone sensitivity -38 dBV/Pa
Wireless range 10 m
Battery type Rechargeable lithium-ion battery
Battery capacity 25 mAh (headphones) / 480 mAh (charging case)
Music play time (50% volume) ANC on: 3.5h (single charge) / 20h (with charging case)
ANC off: 4h (single charge) / 24h (with charging case)
Wired charging time 1.2h(headphones)/1h(charging case)
Wireless charging time 2h (with charging case)
Charging port USB Type-C
water resistance (headphones) IPX7
Weight (Entire device) 53g
Spezifikation
Spezifikation|||
Entwurf
Produkt AirBuds 5 Pro
Farbe Weiß
Gewicht Kopfhörer – 4,0 g, Ladekoffer – 45 g
Kopfhörerabmessungen 33,94 x 21,98 x 19,2 mm
Abmessungen des Ladekoffers 57,69 x 57,69 x 25,54 mm
Hardware
Bluetooth-Version In 5.0
Bluetooth-Profil A2DP1.3, AVRCP1.5, HFP1.6, SPP
Audio-Codec-Format AAC-SBC
Leistung
Standby-Zeit ANC EIN: 5 Std./25 Std.; ANC AUS: 26 Std./130 Std
Spielzeit ANC EIN: 3,5 Std./20 Std.; ANC AUS:4H/24H
Batterietyp Lithium-Polymer-Akku
Batteriekapazität 25 mAh x 2 (Lufthörer); 480 mAh (Ladekoffer)
Aufladestation POGO-PIN (Airbuds); USB TYPE-C (Ladekoffer)
Ladezeit 1,2 Stunden (Airbuds); Ca. 1 Stunde (Ladekoffer)
Paketliste
AirBuds 5 Pro Kopfhörer x1
Aufladekabel x1
Ladekoffer x1
Benutzerhandbuch x1
